Optix MAG301CR2 and blurred fonts
jacekptk15d402ee
I bought the monitor a month ago and since the very beginning I notice the problem with blurred areas on the screen. It's surely a software problem since I'm able to screenshot it (the upper one is blurred and the bottom is correct... as you can see probably :p). It's happening quite random all the time for example in VS Code or Brave Browser and, what's interesting, I don't notice any problems in MS Edge. After focusing mouse on the blurred area it gets sharp instantly. It seems the problem occurs only when displaying text on dark background. I don't notice any problems while gaming. I tried to played with Windows screen settings and wit OSD options but I can't get rid of this. Please help :|
Cheers,
Jacek
Cheers,
Jacek
Try Font setting
Select Next and follow the Set up steps
Hi, it doesn't help but thanks anyway because the fonts looks better now... when they are not blurred. I'm attaching more drastic example from VS Code...
Hard to say cold be Monitor of the GPU
Member @fauc is quite versed in Monitors He may have some idea
It is specification for Optix-MAG301CR2 on MSI website.
PANEL TYPE: VA
Please refer below link first.
What Is VA Smearing And Can You Fix It?
