Optix MPG321QRF-QD
sandrino_a15ed02ea
Hi to all, this monitor is great, i have it by 3 days.
Sorry my english, it's bad.
The noly very bad thing about this monitor is the response time at low refresh rate, it's about how msi have tunning the overdrive.
For a monitor like this we need a firmware with better calibrated overdrive for the VRR or the viariable overdrive like asus is doing.
Fast ti's good for high refresh but make inverse ghosting on 60 hz, pls msi try to address this in the new firmware.
Very thanks and sorry my bad english
clentongar815db02eb
Totally agree with you! The monitor is great, but at low refresh 60/90hz is a problem! Especially when i use 4K dynamic resolution (DLDSR Nvidia) i see bad response time and blur!
This monitor need also a blur reduction funcion type Asus elmb sync because Msi mprt sync its pure ....!
I hope for futures implementations in the firmwares.
(My monitor firmware is last v0.41 and i have Rtx 4070 Ti)
sandrino_a15ed02ea
I fear the monitor is slow, and nothing can be done.
Set overdrive to FAST and play with vrr, at least it's not horrible, i think i will return it if msi will not respond.
clentongar815db02eb
But it's not slow because if you use 120/165hz this monitor works really well 0 ghosting ,0 tearing,0 stuttering with vrr and fast mode (also fastest).
I really like the image quality and colors!
I've seen several reviews of these new similar monitors 32" 2k 165hz ips (from different brands) they all have problems at 60hz!
Maybe someone is faster than a couple of ms but always get a less clear picture.
I think these fast ips monitors are made to be used at high frequencies
So you must have a gpu that guarantees you at least 90fps to avoid going below 90hz.
In 2k it's not a problem for me because the 4070 ti guarantees an average of 170fps, in 4k they're 80/100 but they shouldn't go lower.
Maybe here we needed a 4090.......
But be careful because I think it's a limitation of all these modern fast ips at 60hz mode!
sandrino_a15ed02ea
Hey mate, thanks for reply, the prblem is the ovedrive tunning.
If they made a very good variable overdrive via software the problem is solved, just like when the refresh go near 60 the monitor need to switch to normal, and the problem it's done.
Play every time at max refresh rate/fps it's good but the purpose of vrr it's make the game clear and smooth at any refresh rate.
I'm seeing the Corsair 32qhd240, but can't find review about it.
