Over Clocking Help
minhcl150402d6
Hello, I've been having MSI GV62 8RD for years now, and I still havent touched the over clocking system from dragon center because I am not sure how over clocking works for a thin laptop like this.
What MHz should I raise it up to for Core Clock set, and VRAM clock set to be consider as safe? will 100 MHz for both good enough to not fry my laptop?
The MSI specs is:
Intel Core I5-8300H CPU @2.30HGz 2.30
next3r
MAJOR
locked cpu ,.,,.only possitible unlock Power limit
but your temperatures must be under 90C and lower !! "for OC -70C max or similar now"
,,.otherwise it doesn't make sense
gpu oc --vram no need "TDP is locked" only raising power limit
,.,.core is possitible + voltage lock under TDP
edit ,,.8300h - 2.3ghz base // 4ghz turbo
