Overclocking advice - MSI M5 Z270
Status
Not open for further replies.
dan_lives
Hi everyone,
Its been a long time since I overclocked anything so my knowledge is a bit rusty. I have always been tempted to use the apps and features that come with the motherboard but I never did as I know its always best to manually do this yourself in the bios.
I am looking to overclock my cpu to 5.2ghz.
My system spec:
Intel i5 7600k (running at stock speed 4.2ghz) - I have the Noctua NH-D15 cooler with 2 Noctua fans already attached running in auto mode
MSI M5 Gaming Z270 motherboard
Samsung Evo Plus 1TB Nvme
Crucial 32GB DDR4 3200mhz ram
Nvidia GTX 1050Ti
EVGA 750W Gold powersupply
R5 Fractal Define PC Case with 4 Case fans connected.
I am using Windows 10 x64 Professional.
I am looking for the correct settings and voltage etc to tune this rig up, would appreciate your help :)
Thanks
You will have to find the correct settings out yourself. It depends on the individual components. 5.2ghz is also a bit much asked.
dan_lives
well that was helpful! so much for this forum jeez absolutely useless cunts
Status
