oyun oynarken cpu ısı derecesi
emir61201159b02e6
Merhabalar, cs go güncellemesi cpu ısım belli bir süre sonra 90-95 seviyelerinde oluyor. bu durum normal midir yoksa servise götürmem gerekir mi?
bilgisayarım msi vector gp 78 i9 işlemci 4070 ekran kartı var .
This is a English forum, please kindly post in English.
It is normal if the laptop is not a new one and you played the game for a period of time(maybe a few hours?).
Kindly recommend to select extreme performance in MSI Center user scenario while gaming to make sure the fan works properly.
The fan could work over 5000rpm while the CPU temperature reaches up to 90 degrees.
Thank you for the response. After 2-3 hours of playing, the CPU rises from the 80s to the 90s and 95 levels. I am using the fan setting in normal mode. When I play for hours like this, will the CPU being at 90-95 levels damage the computer?
Not at those temperatures, but if you game daily, expect to have to change your thermal paste in about 18-24 months.
