I am having the issues with trying to use OC genie. When OC genie is on, it reboots itself 4 times from 3.2Ghz decreasing until reaches 2.2Ghz on the 4th reboot and then just halts... and nothing on screen no matter how long i wait. I had to turn off the OC genie and then do a load to optimized default to get it back to 2666hz or it stays as 2.2Ghz. Tried many times, reset the bios using the jumper. tried many things, still not once does it overclocks.
Here is my build:
Motherboard = MSI P55-CD53
CPU = Intel Core i5 750 2.66G s1156
RAM = TWIN3X2048-1333C9DHX G - 2GB (2x1GB) CorsairTwinX XMS3, DDR3 PC3-10666 (1333) 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24, DHX
CPU Cooler = Noctua NH-U12P-E SE1366 (had to purchase s1156 bracket)
GFX = MSI NX8800GTS-512-OC
I can use the MSI Control centre and boost it to 2.9Ghz from 2.6Ghz, but the OC Genie just doesn't work at all.
Its a similar issue with forum post https://forum-en.msi.com/index.php?topic=130938.0 but i was asked to start a new thread!
Oh yeh, I've also upgrade the BIOS from v1.0 to v1.2 and it still doesn't work!
Thanks..
Hoi.
Here is my build:
Thanks..
Hoi.
