Hi All,
I got a problem booting up after updating the firmware from v1.1 to v1.3 for my motherboard P55-CD53. I have follow step by step as according to the guide written by Stu.
My initial Problem
After completing the update, my pc cannot boot up and i saw a split second flash of BSOD follow by my pc auto-restart. Then it prompt me to Launch System Repair or start windows normally.
When I choose start windows normally, my pc would also hang at the microsoft windows logo then follow by the split second flash of BSOD then my pc auto-restart.
When I choose the Launch System Repair, the system repair cannot detect any problems and would prompt me to the end the system repair which I did and the pc will shut down.
After trying the Clear CMOS recommended by Svet
I read and follow the instructions in the Clear CMOS Guide using the old method. I realised there was 5 pin on the JBAT1 with the jumper on 1-2 pin. So I put the jumper into 2-3 pin to clear the data. I then reboot my pc but the same problem still persist. The screen will hang at the microsoft windows logo then it auto-restart by itself. But this time, there wasn't any BSOD.
Please advice me what might be the problem and what is the possible solution?
My specs are as listed below:
Intel Core i5 750 2.66GHz w CM Hyper 212 Plus
MSI P55-CD53
MSI HD 5850 1GB
Team Elite 4GB DDR 3 Dual Kit 1333MHz
Western Digital 500GB Black Caviar
OCZ Modxstream Pro 600W
Running on Windows 7 64bits
Thank you.
My initial Problem
MSI P55-CD53
MSI HD 5850 1GB
Thank you.
