Howdy, folks.
Looking for some information that isn't in the manual.
I have a brand new P55-GD85 that won't POST. Could be a lot of reasons, but I wanted to check that the CMOS jumper on JBAT1 was properly across pins 1/2. The problem: The manual doesn't orient the jumper on the board, and the board doesn't label the pins. Does anyone know whether pin 1 is closest to the battery or furthest from it?
The jumper came from the factory sitting on the pin closest to the battery (plus the middle pin). I assumed that the jumper was properly set at the factory, so I powered down the board and moved the jumper to the other pair for 30 seconds or so, and then re-seated the jumper where it started. Before I did this, powering up the board turned on all of the blue LEDs on the CPU Phase panel, plus LED #1 on the CPU_VTT Phase panel. Now, none of the LEDs lights at all (except CPU_VTT #2 blinks once if I use the reset button on the board). The problem: the manual does explain which LEDs are supposed to light up on boot, normally. Does anyone know? Was all of the LEDs lit a good thing or a bad thing? Now that none light up, is that good or bad? Is there any documentation for this?
The board came with a plastic cover across one of the two, 12 volt 4-pin ATX JPWR2 CPU power plugs (the one closest to the center of the board). Nothing in the manual explains why or whether to use one, two or none of the JPWR2 plugs. Anyone know why one had a plastic cover? I plugged in both halves of the plug, anyway.
Here are the specs on the machine. No overclocking, no tinkering, nothing changed on the board, and no peripherals. I haven't even hooked up the USB headers. Just the front panel power, which I unhooked once I had these problems.
* P55-GF85 w/ i570-LGA1156 (on the supported CPU list)
* 2x2GB G-Skill F3-12800CL9D-8GBRL (correctly seated in DIMMs #1 and #3 -- testing with 1 stick at a time = no change. This memory suggested by NewEgg and reported to work with this board)
* Rocketfish 500W RF-500WPS2, which is not a great PSU long term, but at the moment the board isn't running a single HD or peripheral except some fans. The PSU has 2 12v * 18A rails, and 18A on each of the +5 and +3.3. The manual says "at least 18W" so this may be a problem.
* An old GeForce 6500 card, which may not work, although it gets power.
Thanks, in advance, for any insight.
