P67A-C43 8 pin cpu power will not latch in socket
Alkey42
I just purchased a P67A-C43.  I my power supply did not have the 8 pin cpu power connector, only a 4 pin.  The bottom half of the 8 pin socket on the motherboard had a small plastic cover over it, this is seen in a few pictures of the board I have seen on the net.  I bought an 8 pin adapter, but it will not latch to the socket.  The latching tab of the socket seems offset towards the top, the 4 pin snaps in just fine in the top 4.  Is it supposed to be an 8 pin?  Is the 4 pin good enough?
Simple answer is you don't need any 8 pin adapter for it, use the 4 pin plug from the PSU on the exposed 4 pin part of the MB socket.
Generally if it's an 8 Pin connector and 4 are tabbed over, you can use a 4 or an 8, if not tabbed, it wants an 8 Pin, though this is generally on the very high end boards....it allows flexibility for PSU selection and for adding components or for higher end OCing
