P67A-C43 post codes?
ReverendC
PRIVATE FIRST CLASS
I've got a brand new build
P67A-C43
i5-2500K
2 x 4 GB Corsair DDR3 1333MHz 9-9-9-24 1.50V  Memory
Ultra V Series 500Watt ATX Power Supply
64GB Kingston SSD
1 TB HDD (not installed yet)
SATA DVD-ROM
XFX Radeon HD 6850 Black Edition
PC won't boot.
I'm getting 5 short beeps and cannot find posting codes anywhere.  Actually, there's some other sounds before the 5 beeps.  3 very short beeps with 1 higher pitched beep.
Also all 4 blue diagnostic lights on the board are on and solid.
I've got it set up with just one memory stick in the slot closest to the CPU.
The Power supply has a 24 pin and a 4 pin Power connector.  I noticed the board has an 8 pin connector with a cover over 4 pins.  Not sure if this is a problem.
Any ideas?
@HU16E:
HU16E said:
https://forum-en.msi.com/faq/article/bios-beeps-and-codes
... those definitions are for AMI [Legacy] type BIOS implementations, not for UEFI Implementations.  For UEFI [AMI Aptio] Implementations, the whole UEFI Boot flow is somewhat different, as are the beep code definitions.
@ReverendC:
Have a look at this document:
http://www.xannex.co.kr/doc/ami_aptio_4.x_status_codes_pub.pdf
Please test your board outside the case on a non-conducting surface in barebone configuration:
- CPU + heatsink [check for broken/bent socket pins // make sure the heatsink is not fastened too tight as this can cause pin-contact problems]
- video card [a slightly less powerful video card you can try?]
- one stick of RAM [check both sticks seperately]
- power connectors [do not forget the one for the CPU and the 6/8-Pin-12V connectors for your video card
- keyboard
Unplug EVERYTHING else from both mainboard and PSU, then >>Clear CMOS<< and retest.
If nothing changes, please try a different PSU.
I tried taking the board out of the case (still hooked up to the power button)
I checked the CPU and heat sink.  All seem well.
I don't have an extra video card.
I've tried the one stick only in each slot (with both sticks)
I have checked the 24 pin main power connection as well as the 4pin connection.  My card does not have a separate connector for power.
Will try clearing the CMOS when I get back home and then a different PS.
I did notice that when the are no memory sticks, the pc just seems to get stuck in a power up cycle with no post beeps.  The fans spin up, lights on the mobo light up and then everything turns off and repeats.  about every 5 seconds.
Then, I think, we have found the cause of your problem.  It must have at least one 6-Pin/PCI-E-+12V power connector!  Power output via the PCI-Express bus is limited to 75W by PCI-Express bus specifications, however, your card needs way more than that [~127W]. Look at the back of the card for the power connector:
You can see the position of the connector on the following picture which shows the PCB of the card only:
Five beeps during main hardware initialization (Driver Execution Environment (DXE)) [= equivalent to the P.O.S.T. Routine of legacy BIOS Implementations] usually means:
No Console Output Devices are found
[check page 12 of the "Aptio 4.x Status Codes" document.]
You definately need to connect your card to the PSU, otherwise it will not get enough power and can't be initialized.
Thanks Jack...for making me feel like a moron.
Not sure why pointing straight to the cause of the problem and thereby indicating the only solution is considered as some sort of offense.  :think: Would you rather have had a defective piece of hardware?
