P67A-GD55 THX TRUSTUDIO NOT INCLUDED????
benjaminhon
audio genie says to install THX TRUSTUDIO, yet the software is not included in the cd. to make matters worst, the software is not even downloadable from: THX or Creative or MSI websites.
How do you you install THX Trustudio?????
can anyone help? thanks
THX TRUSTUDIO Pro is "a high-fidelity sound reproduction standard" that the onboard Realtek Soundchip supports, not a special software or a utility.  Install the latest Realtek HD Audio drivers is enough to make this standard "available".
hi jack,
but in Audio Genie it says to install THX trustudio pro to access the features.
when i click on audio genie => thx, i cannot access the trustudio pro features such as the crystalizer CMSS and stuff.
from what i know from searches, the other motherboards that support THX trustudio also give the software to them.
how come it is not included?
Do you have a sys tray popup like this? If so, look for the THX Icon. If there, then you have it. :-))
You did install the Audio off the MSI Driver/Utility DVD didn't you?
yes i have the realtek audio installed.
but no trustudio.
i downloaded trustudio from another company which integrated trustudio into thier motherboards (asrock) but i dont know if it is installed correctly, looking at your system tray,you have THX (the black icon installed) how do u get that? i only got that after i downloaded from asrock.
it is not provided in the MSI product or on the webpage.
Trustudio Pro is not just a standard, there is a software that goes along with it to control the hardware abilities....
Granted, my boards are different than yours, but it should have been on the install DVD when your Audio driver package was installed. It sounds to me like it would be best for you to contact MSI Tech Support with a ticket. They should have some official answers for you.
What HU16E suggested was to "contact MSI Tech Support with a ticket" and NOT to open another thread about the same question in some other section of the same user-to-user forum.  OF COURSE I locked that thread and I will do it again without hesitating.
You can contact MSI Technical Support here: http://support.msi.com/
Before you so, however, please install the latest Realtek HD Audio Drivers for your operating system:  http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false ... and retest.
Also, this is a user to user forum and NOT official MSI technical support.  To contact MSI technical support, use the link Jack provided above.
I got THX Trustudio Pro utility (and small THX icon appeared to system tray as well) from here (actually it is meant to MSI GE620 Notebook but it is working with my P67A-GD65 B3 as well): http://drivers.top4download.com/msi-ge620-notebook-thx-trustudio-pro-utility-1-02-11/deehj.html
