Hello there,
I have the P67A-GD65 (B3) mobo, with an i2500K at 4.5g, cooled with an AC Freezer Pro Rev 2.
Under Prime95, the temps are up to 74deg, which would probably be ok, but I'd like to get these temps down, especially with Summer on the way and as the Freezer isn't exactly high end, I'd like some advice as to coolers that fit the mobo.
I did get a second hand Titan Fenrir, but the bracket hits the "Military Class" SFC unit (sorry, I'm not sure as to what this is), so I can't use that.
My case will take a cooler up to 163mm and I'm using Corsair XMS3 PC3-12900C9, so I don't think these will cause any problems.
Thanks for your help.
