spt_2151102d1
- Feb 2, 2026
Hi everyone, I’d like to explain my situation. I’ve been dealing with this for months and I can’t figure out what’s causing it.
About a year and two months ago I built a new high-end PC from parts (I assembled it myself). Everything worked perfectly at first. A few months ago (I don’t remember exactly when) I updated the BIOS, and I think the issues started after that.
This only happens on a cold boot (after the PC has been off for many hours or overnight). If I reboot, or if I shut down / sleep and turn it back on shortly after, it boots fine.
The problem is that sometimes on a cold boot the system becomes extremely slow right from startup—so slow that even the Windows login sound stutters/cuts out. A couple of times Windows has even rebooted by itself because the system was running so badly.
I’ve tried a lot already: updated the BIOS again (I’ll list my full specs below), disabled XMP/EXPO, disabled HAGS, unplugged all non-essential USB devices, and even reinstalled NVIDIA drivers using DDU in Safe Mode. The issue still happens and it’s very frustrating.
To be clear: this is only on cold start. Once the PC finally boots normally, it runs perfectly for as long as it stays on.
I’m a software developer—not a Windows expert, but I’m comfortable with the basics.
I suspect it’s BIOS-related (not 100% sure). When I updated the BIOS, I also tried a “gaming”/AGESA mode that basically changed my CPU from 16 threads to 8 and optimized for games. When I tested it I noticed the PC was slow, so I reverted the settings in BIOS. I’m not sure if that could have affected anything long-term, and I can’t remember if the issue started right after, but I’m mentioning it in case it helps.
Would you recommend updating the BIOS again? The only newer versions available are beta. Can I safely roll back to an older stable BIOS version to test?
The weird part is I’ve checked with LatencyMon and it doesn’t point to a clear culprit. I also don’t see any major CPU/disk usage spikes in Task Manager when it’s slow—everything just feels sluggish as I open processes/apps.
I’m pretty desperate at this point and starting to worry it could be the motherboard. Here are my specs:
- Motherboard: MSI X670E GAMING PLUS WIFI (BIOS 7E16v1B)
- CPU: AMD Ryzen 9800X3D
- GPU: NVIDIA RTX 4080 Super AERO
- RAM: 2×16 GB Corsair Vengeance 6400 CL32
- Storage: Samsung 990 PRO 2TB NVMe
- AIO: CORSAIR iCue Link H150i LCD 360mm
- PSU: Gigabyte GP-UD850GM PG5W/PSU
