hupimies2151a02d0
- Sep 22, 2024
Board: X670E Tomahawk WIFI
BIOS: 7E12v1E
GPU: AsRock RX 7900 XT Phantom Gaming OC
CPU: Ryzen 7 7800X3D
Cooler: Noctua NH-D15
RAM: 2x16GB Corsair Vengeance 6000MHz
SSD: Samsung 2TB 990 PRO
PSU: Corsair 850W RM850x
SYS: Windows 11 Home x64 Ver. 10.0.22631
About 7/10 times the pc wakes up normally from sleep mode, during which red and yellow light on motherboard (CPU, RAM) flash. 3/10 times the lights light up for about 30 seconds, after which they turn off about the same time. After this only black screen, USB devices get power (leds on mouse light up, not on keyboard) but no other connection. Have waited for over 30 minutes, no change. Always gets fixed by forced shutoff via holding down the power button, after this boots up to saved state (previous applications open etc.) No problems on regular startup.
Worked normally for about a year, problem started a few months ago suddenly. Didn't disconnect or open up the PC / download any software / do anything else notable which could have caused system change. All temps during benchmarks normal and no problems during running. PC has never crashed etc.
List of things that have not fixed the problem:
Updated BIOS
Reset BIOS settings through BIOS menu, haven't cleared CMOS with jumping
Updated GPU drivers
Updated Windows from 10 to 11
Reset Windows power settings through troubleshooting
Turned off fast startup
Unplugged and reconnected PSU (also removed and reconnected GPU, didn't try to boot without it)
RAM are in slots A2 and B2 per the manual, as they have always been
Not a huge problem, but very annoying since I primarily keep PC in sleep mode. Also have to think that constant forced shutoff doesn't do the PC any favors. Any thoughts on possible fixes? Could clearing CMOS have any other effect than resetting through the BIOS menu does?
BIOS: 7E12v1E
Updated BIOS
Updated GPU drivers
