pcie x1 first slot issues
xris.easo157302da
Have recently got a ms-7567, gf615m-p33 v1.2. Updated to latest BIOS I could find (7597v2a) thanks to this forum.
Trying to get a intel pcie x1 card to work in the 1st slot (above the pcie x16 slot). Im not using a graphics card, have a nvme ssd in a pci riser working good in th x16 slot. Can also swap out the ssd for the nic and that also works. No go on the x1 slot. Don't have any more mobos to test on, so a bit in the dark in terms of troubleshooting.
Anyone tried this combo before? would the slot be mutually exclusive (cant use both at the same time)? don't seem to find info on this.
Cheers!
darkhawk
The forums infamous moderator
I'm going to be honest......You're talking about hardware that's close to 2 decades old now.....finding support for it is going to be pretty non-existent at this point, unfortunately. Most middle of the road cell phones are probably more powerful than this system, sadly.
Alan J T
Demon God
Cheers!
What is the PCIE card if it is a newer model it may not be supported
