(PCR7)call of duty mw4 problem
craigben30
PCR7 log-format bug (the common firmware defect): the BIOS doesn’t write the standard Secure Boot events (EV_EFI_VARIABLE_DRIVER_CONFIG / EV_EFI_VARIABLE_AUTHORITY) into PCR7, and writes a vendor-specific event instead. Symptom: tpmtool getdeviceinformation shows “PCR7 Binding: not possible”. Not user-fixable.
The only real lever: report it to your manufacturer as a firmware spec-compliance issue (not as “CoD won’t start”), ideally with your decoded TCG log showing the missing/malformed PCR7 (or PCR0) events. Lead with the firmware behavior, not the game symptom – otherwise it gets filed as a game-support ticket. The more precise reports they get, the more likely a fix – and one fix often covers a whole model line sharing the same firmware module.
i have the pro H610M-G ddr5 motherboard and i have fully updated my pcs firmware/bios to play the new cod but i am simply unable to this bug and i was wondering if this could be fixed at some point so i can play the new call of duty
i will also add that i am on a prebuilt pc too if it matters and i bought it from a retail store
https://steamcommunity.com/app/1938090/discussions/0/582803950825126152/
that is the link to the steam thread.
now i could still be wrong and just coping by hoping that the person on steam is correct but i would still like to know if i am able to get around this
Being pre-built matters as it is most likely a custom BIOS. They are not usually updated as often as the retail ones. List the full bios name as it shows when you go into the BIOS pages, and we can figure out what you need.
MAG Infinite S3 13th​
Now i remember it was this exact case plus bios version so it may have had something not just with the motherboard but the entire desktop i forget that the whole desktop had its whole specification if it was a prebuilt
also extra question, is there not a way to just be able to update the motherboard and not have to go for the desktop specifically?
If you mean flashing the channel motherboard BIOS to your desktop system, it is not allowed officially.
If you do so, it can break the warranty and cause unexpected problem.
However, you might be able to do that with moderator tool,
>> Forum Flash Tool <<
but they don't hold any responsibility for any error happening afterwards.
>> Forum Flash Tool <<
i dont even have warranty in the first place so it wouldn't matter anyway but i could try this but then ill be out of a pc if it doesn't work i don't know how regularly these desktops even get bios updates either so i could be waiting a very long time for the update to even be here
On a hp pre built I bought in 1998 during the 5 years my kids played on it I had 2 bios updates. On a retail board I built my computer with I had 5 bios updates the first year of course it was a DFI which are not around anymore.
Yep, reset the TPM/Clear via Settings in Windows
It tends to work, but not always
Verify Windows has updated all security Keys
If the MSI motherboards has been fully updated and the new certificate is active, you can find an entry in Event Viewer → Windows Logs → System with the source “TPM-WMI” and Event ID 1808.
If it fails, then you will need to do a Clean install of Windows
Say thank you to Activision for wasting your time with their wonderful Player support
See FAQ
https://www.msi.com/faq/11365
See FAQ
i tried all of the stuff and not i think i have to clean install because it didnt work, will i need to format my usb specifically for this and does it act like a factory reset or will it be all the same when i reinstall it?
i also have the 1808 id thing so its up to date
now it even comes up with an extra popup
If CODBrokerInstaller.exe can authize your PC using not PCR7binding but PCR0binding, then the reason CODBrokerInstaller.exe cannot install the private key for COD on the TPM is likely because WindowsHello is disabled. If so, try to enable WindowsHello somehow.
If CODBrokerInstaller.exe requires PCR7binding to authorize your PC, you can't play the new Call of Duty on MSI Pro H610M-G DDR5 forever.
This is because the MSI Pro H610M-G DDR5 cannot build a certificate chain rooted in Microsoft's PK certificate. This is a motherboard specification and is virtually impossible to fix.
Looking like this is becoming a trend I have Prebuilt 14th gen MSI MAG S3 brand new out the box literally last week and this is happening to me tried every “Fix” I can find to no avail , seems there are a few other threads on here in the last few days for the same thing..
