- Dec 5, 2009
I have a MSI P55-GD65, I have updated the bios to the newest version and now the phase led are working wrong. the are always burning and if I use the processor led 1 goes out.
NovJoe said:
I am new here.NovJoe said:May I know how you flash the BIOS? Using LiveUpdate or the forum USB flash?
NovJoe said:I suggest that you clear CMOS and see how it goes. I'm against using LiveUpdate myself as flashing a BIOS through Windows is never since there are so many running applications in the background.
NovJoe said:It is the best way if you know how to do it.
NovJoe said:I suspect that it may be due to a BIOS corruption when you flash using LiveUpdate. I recommend you to RMA the board for a replacement.
chef jeff said:We are all end users here not employees of MSI. Liveupdate is not a forum tool.
NovJoe said:You have already cleared CMOS, right? If clearing CMOS doesn't helps, then it is a different problem from the thread you have posted.
Regarding the LiveUpdate question, like Jeff mentioned, we are like you - end users ourselves. This is a community forum where users come together to help and share with each other. If you wish to use LiveUpdate for any upgrades of BIOS or drivers in the future, then you should log a ticket with MSI support. Otherwise, using the forum USB flash method for BIOS flash and downloading the drivers from the website will be a better option.
NovJoe said:I recommend you to >>Use the MSI HQ Forum USB flasher<<. It is a much better way of flashing BIOS for MSI boards.
