Please Help! Bricked my GS60 6QE 4K Ghost Pro, how to blind flash?
jamesoliverstone
Please can someone help me, I just did a bios update, followed the instructions and now my laptop is dead, just a black screen. Is there any way to blind flash the bios on these laptops?
Do [Reset] and check the problem again.
How to do the [EC Reset]?
1. Remove the AC adapter and insert the straighten paper clip to [Reset hole] which is located at the left/right side of notebook or the back cover.
2. Wait 10 seconds and connect the AC adapter. Then, you could power on the laptop again.
If it doesn?t work, you might need to contact with repairing center.
Thanks for that, unfortunately I tried that already with no luck. I need to know the procedure to blind flash the bios
