nicksiew920
- Sep 6, 2026
im using intel 12700F ,msi gtx980 ,savage DDR 4 rams,kingston ssd 480gYou need to update your bios. Since you cannot get to Click Bios, your other option is to do a BIOS Flashback if your motherboard is equipped to do that.
If you have an Intel CPU that does not have the letter "F" in it, you could remove the discrete GPU and your computer would automatically use the integrated graphics of the CPU. Then you would get to Click BIOS by pressing the DEL key on power up. Once in Click BIOS, update your bios using the M-Flash method.
If you have a much older GPU card, you may have to update its VBIOS. Search this forum using "white screen"
No,i,m just bought this motherboard , rams , cpu , ssd and want to start new pc install,only graphic card is from old pc part.izzit this motherboard can,t support Msi GTX980 ?my monitor model is Msi Optix G32C4Your motherboard does not have the BIOS Flashback feature.
Some background please: You had a working computer before this happened? Did you change something prior to this white screen? Was there an automatic update to your computer that may have caused this white screen?
If i use Msi Rtx 3070 Ti izzit ok for tht?The graphic card doesn't support UEFI mode, that's why you can't see the BIOS screen.
Here is the link to your motherboard's compatibility webpage, VGA page. Check it out.If i use Msi Rtx 3070 Ti izzit ok for tht?
Should be alright. Some of the 30 series cards needed a firmware update, not sure if that was one of them.If i use Msi Rtx 3070 Ti izzit ok for tht?
