Poor font look
energo154202da
I have G27C4 Monitor, games looked perfect, but working with text is pain for my eyes. I prefered work on my old monitor with yellow effect...
Can you help determine problem?
I'm attached screenshots with new MSI monitor and my old. Look at font, it does not have flat black font line, looked as smoothed with pink..
Both monitors connected to same PC with same same system settings
Administrator
You can try to run the "Adjust ClearType text" tool re-apply the best settings.
Else can suggest you to check the monitor refresh rate and its depth color:
Sometimes on some monitors they wake up from sleep in wrong color mode and refresh rate,
which applies some pink issue to the fonts with poor font resolutions.
Aside from this, your monitor is a VA panel, with big PIXEL PITCH,
its normal to notice those if you are at close distance.
