Power connections on motherboard and GPU
NekoYami
Hello, I'm going to build a PC soon with:
- MSI PRO B760M-A WIFI DDR4 motherboard
- i5-13400F processor
- RTX 3070 Ti FE graphics card
- MSI MAG A750GLS power supply (PCIe 5)
Knowing that the power supply only has 3 CPU/PCIe connectors, that the motherboard powers the CPU with an 8-pin + 4-pin connector, and that the GPU is powered via its 2x8-pin to 12-pin adapter, will using an 8-pin cable for the CPU and a 2x8-pin cable for the GPU cause any problems ?
Thanks.
No, you just need the 8-pin for the CPU; the 4 pin is not needed unless you plan to overclock
