J Jonas Guest Aug 11, 2002 #1 Power DVD 3.0 or MSI DVD in XP? Wich is the best dvd program for win xp?
Wonkanoby New member GENERAL OF THE ARMY Joined Jul 7, 2002 Messages 31,259 Aug 11, 2002 #2 well power dvd 4 works with xp but id check for a patch to get 3 first as im not sure it will without one Upvote 0 Downvote
B Beltxo Guest Aug 11, 2002 #3 MSI dvd works fine with XP, but may be you may consider use nvDVD (the nVIDIA player). Take a look at this thread: http://www.msi.com.tw/program/service/forum/index.php?threadid=1147&boardid=9&styleid=1. My opinion: -nvDVD: gold medal -PowerDVD4 XP+patches+any dvd tweaker, silver medal -MSI DVD player (WinDVD), bronze medal, or maybe no medal.... Upvote 0 Downvote
J Jonas Guest Aug 11, 2002 #4 Ok.Thanks. BTW the NVDVD,doesnt i need a serial key if i download it? Upvote 0 Downvote
B Beltxo Guest Aug 11, 2002 #5 -- OFF RECORD--- ... if you search at filemirrors, you will find a "serial-less" version... ---------------------- Upvote 0 Downvote
V Vcmc6623 Guest Aug 14, 2002 #7 MSI DVD work well in Win XP. :] When I use the Power DVD, My pc Hang???? X( Upvote 0 Downvote
