Power Issue
septaxyz12129202a8
My Claw is dead. After i unplug the power , my claw goes off. I press the power button and the fan blowing hard and vibrate, but the screen still off.
Anyone have the same issue like mine? Need help
Try to connect an external monitor to check if it shows the screen or not.
If the external monitor is showing, try to do EC reset.
But you would need to be careful to check the BIOS version first, if it is E1T41IMS.109, you would not able to boot into the system after EC reset and you will need to update BIOS to the latest version(E1T41IMS.10A) by a USB flash drive.
