kevin210320015ba02e6
- Jun 3, 2023
hello i want to buy extra power supply for the MSI Optix G27CQ4 only what do i power adapter do i need to ordert
can you link me a good onethe original is a
Voltage: 20V
Current: 3.25A
Plug Size 5.5mm X 2.5mm
its a Fairly Generic low end Laptop PSU so are Fairly Common.
its hard to do as there are Many as its a generic 65W Laptop Charger Mostly MSI will use DA-65C19 or Similarcan you link me a good one
yes i dont have anny clue of what i need if you can link me one i can search further for other brands or maby cheaper i now see this https://viadennis.nl/adapter/msi/ms...HL7_y7ckQxTJEUrUKE841yaY4WzlQb1xoCW24QAvD_BwEits hard to do as there are Many as its a generic 65W Laptop Charger Mostly MSI will use DA-65C19 or Similar
that should work its just a Higher Wattage unit but the screen will only pull what it needs.yes i dont have anny clue of what i need if you can link me one i can search further for other brands or maby cheaper i now see this https://viadennis.nl/adapter/msi/ms...HL7_y7ckQxTJEUrUKE841yaY4WzlQb1xoCW24QAvD_BwE
