Power Supply Wattage Recomendation?
landry92m
What wattage should I be getting for this setup? I currently have a 750 gold, is this good for this setup?
i7 10700KF
rtx 3070 suprim x (gaming and mining)
Gtx 1080ti Amp Extreme Zotac (mining)
4x8gig rams
1TB SSD
6 rgb fans (+2 on cpu)
badboy2k
i7 10700KF
4x8gig rams
1TB SSD
it should be adequate but personally i would have oversized it to 850W as the RTX 3070 likes to take huge gulps of power at random.
landry92m
Ok awesome. Ill probably get the 1200w only once I get the third gpu. But for now, If I keep the 750w to run the 2 gpu's, or upgrade to 850w to run them, can I run both 4 (8pins) to the gpu's? Here a pic:
As for the 3070, I am using VGA 1 + VGA 2 but for the 1080ti, could I use up the second VGA 1 + CPU? I'm confuse because, 1 (8 PIN) says CPU, and 1 says VGA2 & CPU. If you can clear that up for me that would be great. If I can only use the 3 VGA that it got, ill have no choice to use a splitter on the 1080ti?
badboy2k
if you use 2 3070's you would need around 950W.
what 2 GPU's will you use as even a 3070 and a 1080ti would need 900W (may get away with 850w if the 1080ti was not under much load).
as for the connectors on the back the PSU comes with 4 8pin PCI-E connections as the 3 marked GPU are 2 are single 8 pin leads and the other is a Daisy Chain of 6+2 lines times 2 on a single lead.
the one marked CPU is an additional 8 pin CPU power connection for boards that need 2 8 pin Connectors.
GWraith
The bug hunter!
Someone is getting into mining.
Anyways, there is a ton of power supply calculators on the internet.
