Prestige 14 Flip AI+: MSI Center S window is too large on external monitor
ReneG
When opening MSI Center S on an external high resolution screen, it appears way too large.
The window controls on the top aren't even visible.
The window content looks too big.
After making the window smaller by dragging on the edges, it won't stay that way if it is closed and opened again.
It appears to be a scaling issue. Scale is set to 100% in windows. Changing the DPI compatibility settings in windows for MSI Center S didn't help.
How is the resolution on your external monitor? Mine seems to be fine with 2K resolution.
But yes, the window cannot retain its previously adjusted size.
Just to sync up, which version of MSI Center S are you currently using?
The resolution is 3440x1440. Aspect ratio 21:9.
MSI Center S version is 1.1.60128.0
