Printer Issues with x-58
Gibson
STAFF SERGEANT
Hey guys, its been a while.  I'm having an error where i cannot use my printer. Basically i will plug the printer in via usb (front or back, i've tried both), and nothing happens.  When i check my device manager, whichever usb port that i plugged the printer in is flagged with a error sign.  This doesn't happen with external drives, controllers, mice etc.  I've also confirmed that this printer works on other computers.  I downloaded drivers directly from hp, my printer model is a PSC 1600 All-In-One. I've included an image of the Device Driver with the USB ports flagged.  Thanks   link:  http://i53.tinypic.com/2wnti5i.jpg
Are you sure that the drivers for that printer come with the OS?  For instance, W7 includes drivers for my 6980 and there are no drivers to download for W7 on HP's site, but, for your PSC 1600 series, there are drivers to download for W7.
Windows doesn't try to install drivers because the printer isn't recognized at all.  The drivers i downloaded from HP were for 64bit win7
Unplug the printer and then please download the latest Intel Inf Chipset driver installation package for W7 64bit from Intel:  http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=18494&lang=eng and run it.  Then restart the system and test your printer again.
I updated the intel chipset drivers, but no dice.  Plugging the printer in crashed my computer when i was trying different USB ports, so i dont know whats up.  Thanks for the help
Solved**
Turned out that the pins inside the printer USB connector jack were all bent and pushed in...lol. I managed to straighten them, and it was fixed. Dumb problem... sorry if i wasted your guys time.  Although i don't know why it would crash my computer/ temporarily disable the USB ports. Thanks for everyone's help
-Gibson
Gibson said:
Solved**
-Gibson
I imagine there was a short circuit in the jack/plug causing that.
Solved**
-Gibson
thanks for the information!
Solved**
Users on the MSI forum thread are troubleshooting printer issues with an X‑58 motherboard setup, where the symptoms range from printers not being recognized to print jobs getting stuck in the queue. Several contributors point out that outdated drivers, incorrect USB settings in BIOS, or conflicts with installed security software can all interfere with normal printer communication. Some suggest reinstalling or updating drivers, checking USB port functionality, and ensuring that the motherboard firmware is up to date to rule out hardware‑side glitches. Others emphasize the importance of narrowing down whether the problem is software related or a hardware/connection fault, since that makes it easier to apply the right fix. The thread reflects the kind of practical, step‑by‑step problem solving you often see in tech‑support forums. In a related vein of improving document workflows and handling files more efficiently, reviewing options at https://comfax.com/reviews/best-online-fax-services/ can help you choose a reliable online fax solution that simplifies sending and receiving documents without relying on traditional fax equipment.
The X-58 error can have different causes depending on the printer brand and model, so it helps to know the exact manufacturer. As a few general troubleshooting steps, try turning the printer off, unplugging it from the power source for a couple of minutes, and then restarting it. Also check for any paper jams, make sure the ink or toner cartridges are installed correctly, and inspect the printer for any obstructions.
If the error persists, please share the printer's make and model (for example, HP, Canon, Epson, or Brother), along with when the X-58 message appears. With that information, forum members can provide more specific troubleshooting steps.
