oliverrforsyt14e202d1
- Dec 10, 2023
Figure I might as well give this place a shot...
So for the past week, I've been trying to build a new PC (my 2nd one), and everything else works fine... however, I am not getting any signal to my monitor, and cannot even get to the BIOS.
The debug LED lights for the CPU and DRAM light up, however I have checked both multiple times, and there is no issue with them.
I tried plugging the RAM in different slots thinking that might help, but nope. The CPU is firmly in place too. I tried both monitors (one DP, one HDMI), and I know they do work, but nope. I tried them in both the motherboard and GPU also.
I figured maybe taking the CMOS battery out for a few minutes to see if that might do anything (as was the case with my last build, typical I get these issues, huh), but nope.
I'm at a loss of what to do, I've tried everything I could find. Could it be a faulty motherboard? Is there something I haven't tried?
Besides my motherboard that's in the title, my specs are:
GPU: MSI GeForce 3060 Ventus 2x
CPU: AMD Ryzen 5 7600
RAM: TEAMGROUP Elite 16GB (x2) DDR5
Any and all help will be greatly appreciated, and I'd probably name my first born after you
Thanks!
EDIT: The issue was the DDR5 RAM not being in as well as it should have. DDR5 requires a bit more force to install than DDR4, apparently.
Thanks!
