CPU: i7-13700KF
RAM tested with: Corsair CMK64GX4M2D3600C18 or Kingston KF436C18BBK2/64
BIOS: v1.9
Issue: No way to get XMP, DDR4-3600 or gear 1 to boot or run stable.
I've used this motherboard before with Intel 12th gen and 64GB DDR4-3600 was not an issue then but the same doesn't go for Intel 13th.
There's some weirdness with this motherboard such as XMP timings and voltage being applied even though XMP is disabled.
There's no way to get gear 1 working. I get the occasional boot with 3600 G2 but it's not stable. Tried auto SA voltage and manual.
Even this failed OCCT: XMP off - 3200 G2 - 18-22-22 - mem 1.25v (which is basically very close to JEDEC).
At moment I've managed to get the following stable with the Corsair memory:
- XMP off
- 3000 G2
- CL17-21-21-21-39
- SA voltage: 0.8V
- RAM voltage: 1.25V
Really not an ideal setting for this CPU. Clearly this BIOS still needs work.
Just last week my B660M-A + 13700KF build had no issue with 32GB DDR4-3600 so it seems to be related to the 64GB of RAM (maybe dual rank vs single rank).
BIOS: v1.9
- XMP off
- 3000 G2
- CL17-21-21-21-39
- SA voltage: 0.8V
