lowdominio154d02de
- May 16, 2022
Hi Everyone,
Full part list for the build at the bottom.
My first time build won't post so I'm looking for some support on additional steps to take in my debugging process. My case powers on and all fans, CPU cooler, RGB power up as well. Problem is I get not display and on the motherboard the red CPU light flashes for 2-3 seconds then the yellow DRAM light quickly flashes then back to red back and forth. From what I understand of reading the manual the lights should stay solid if neither CPU or DRAM were not detected. I did some further research online and tried a couple of things others have tried with similar debug lights but nothing so far
1. I pulled out the DRAM and reseated them both in MSI recommended slots for 2x install A2 and B2 I believe.
2. I pulled and reseated the power all the power supply connectors on both the motherboard, GPU and the modular end of the power supply.
Those were the first simple things I tried but wanted to get some advice before pulling apart more of my machine if I can help it. In case I'm missing something that may be more obvious. I know some people have recommended removing and re-inserting the CMOS battery but from what I ready of this board it's buried under a heatsink and it's not recommended for replacing by inexperienced users like myself haha. I've also heard some people recommend other re-flash the BIOS. This is another step I wanted to avoid before seeking out advice. Lastly and maybe most simply is DRAM compatibility. I was unaware at the time when I bought everything some DRAM4 from major brands may no be compatible with my motherboard. I looked for my model DRAM on MSI list of compatible RAM and I did not see the specific model. (CORSAIR 16GB 2X8 D4 3200 C16 VLPX). I've also read that the list by MSI is not often kept up to date and they maybe otherwise compatible and they just haven't tested it.
Thanks for reading this far! I'm just dealing with information overload at this point. If anyone can look at my part list below and let me know if something is blatantly incompatible or I'm otherwise missing something simple to try I would greatly appreciate it!
