Tech-Support pro b760 p2 rx5060 freeze
Troubleshooting
frederic_laurent2
Hi all,
need your help about this setup
My issue is :
freeze in on windows after a couple of minute except if you start counter strike on steam :) I known ...... bizarre. Can play 24/24 without freeze.
Work properly in rescue mode.
Driver up to date and bios up to date.
Tried disabled OC xmp and all. Modifed C-state.
Tried to stop all services and re-installed nvidia driver on WIN11.
Will cry soon...
Any idea?
Thanks for your help.
Usually there's no need to try special BIOS settings, it should be stable and not freeze on default settings. Of course, XMP is a potential source of instability, but then it should be unstable everywhere, in games too.
So it could indeed be something in Windows here. The best thing to try is to do a fresh install of Windows 11 to a spare SSD. Can be any old SATA SSD with 128 GB or so, just a fresh install to it, then only installing the basic drivers like chipset drivers, graphics drivers. If it doesn't freeze anymore, it's something with your existing Windows installation.
Was this a Windows installation that you took over from an old system, or did you do a clean install of Windows when you put this system together?
Thanks for answer!
At start was a fresh install with whole new parts. Issue arrive a couple of weeks after. I think it's really hardware error because same arrive with a boot on linux live usb. I already re-installed Win11. After find some clue about undervoltage on I7 13th and 14th gen. When I monitor the cpu voltage, and you play you can see cpu voltage rising and no freeze occurs. But when you come back to desktop an 0,65V, freeze come quickly. It seems the CPU is unable to work with this voltage.
I will try to get the warranty on intel or my seller.
Thanks
