PRO-B760M-P (DDR5) + 13700k / CPU power draw limited to 135-140w maximum / limited performance
We have assembled following configuration :
MB : MSI PRO-B760M-P (DDR5)
CPU : Intel 13700K
CPU Cooler : ZALMAN CNPS20X (300 Wattish air cooler)
RAM : Corsair Vengeance 6000 MHz DDR5 2x16 Gb XMP C36 cmk32gx5m2b6000c36
Power supply : Inter Tech Argus GPS-700 / 700 Watt
GPU : Gigabyte GTX 960 GV-N960IXOC-2GD
As per product page, the MSI PRO-B760M-P is compatible with 13700K CPU.
We performed various stress tests with the CPU (OCCT, Cinebench etc..). The CPU package never consumed more than 135-140w. Also confirmed by our external Watt meter.
We have then installed the latest bios version : E7E02IMS.A20. We also modified following settings in the bios :
- Adv. CPU Configuration\PL1 : 135 (default) => 175 watt
- Adv. CPU Configuration\PL2 : 150 (default) => 200 watt
The CPU still draw 135-140 watt maximum. No change in performance. Cinebench R23 multi core result is 24000 instead of 30000+. This is not normal. For information, at maintained 135-140w, the CPU Temp was below 65°C.
In the BIOS, we noticed a limitation with the "CPU Cooler Tuning" setting, the 3 proposed options are rated at 135 watt :
"Boxed Cooler (PL1: 135 W)"
"Tower Air Cooler (PL1: 135 W)"
"Water Cooler (PL1: 135 W)"
This is pretty consistent with the issue we are facing.
Please advise if you have any idea other than getting an updated version of the BIOS from MSI.
Best,
Julien
This board is too low-end for this CPU, that's the simple explanation. The "PRO" boards are the most entry-level boards, and the -P are even the most entry-level variants of them, and the B-chipset means further cost savings and limitations. This is entirely the wrong choice for a 13700K, i'm afraid.
You have to differentiate by what is meant with "supported" / "compatible". Support for all 13th gen CPUs is stated on the QVL. So in theory, it supports everything from a Celeron to the 13900KS. But those will put vastly different requirements on the VRM (voltage regulator module, what supplies power to the CPU). So what you also have to keep in mind is to match the CPU to the board you have. "Support" from the BIOS side only means that when you use such a CPU, the board will turn on and work with it. Not how well it works under full load.
The problem with cheaper boards and their cheap so-called "discrete MOSFETs" in the VRM is, those MOSFETs have higher switching losses, which means a higher heat output from the VRM (more power going to waste in form of heat). When you have a considerable CPU power draw like the 13700K would have (if they'd allow it in the BIOS), it can heat up the VRM section so much that you get VRM-induced throttling, no matter how well you keep the CPU itself cool. When you want to use a 13700K on a B-series board, you need to go for a better board model, in order to get a decent enough VRM.
The MSI PRO B760M-P has only 6x 55A SM4337 Hi-side / SM4503 Lo-Side discrete MOSFETs for VCore, 2x for SoC, = 3+1 phases in dual output / teamed configuration.
It has no VRM heatsinks whatsoever. For comparison:
The MSI MAG B760M Mortar WIFI has 12x 75A RAA220075 Powerstages (combining Hi- and Lo-side MOSFETs), 1x for SoC, = 6+1 phases in dual output / teamed configuration, and the VRM is fully heatsinked.
Also the Mortar has PCIe 5.0, two more fan headers, integrated rear I/O shield, additonal PCIe 3.0 x16 slot (@x4), more and faster USB ports, front USB-C header, 2.5 GBit LAN, Wi-Fi 6E, RGB headers. But the most important thing is the much more capable VRM.
With your board model, a i5 non-K model is the maximum that will run without being slowed down. If you want to use i7/i9, this is not the right board to pair it with at all.
Personally, i'd never get a board where the VRM is not fully heatsinked. Heatsinks are even more important to use with discrete MOSFETs than they are to use with powerstages, so the board makers got that aspect backwards. The cheaper the components in the VRM section, the more they need heatsinks!
On the cheaper board models, the CPU VRM is less sophisticated and uses cheaper components and less phases. Here's an example of what happens when you put a high-end CPU into a board with an insufficient VRM section:
"When the Ryzen 9 5950X is under full load, the VRM section of the ASRock A320M-DVS (budget board model) is roasting at over 120°C."
It's a different board and CPU, but the same basic setup (cheap board model + power-hungry CPU model).
Here i explain more how the board makers always try to save money on the VRM components, whenever possible.
A 13600K (!) can already draw around 180-200W under full multithreaded load. The cheapest boards just cannot handle that continuously with their inefficient MOSFETs in the VRM. The VRM will overheat and then you'd get VRM throttling. You'd have to enforce lower power limits to prevent it. Here, MSI do that for you, i'm afraid. With the cheaper B-chipsets, you need a mid-range board at least. Only with the Z-chipsets, a lower-end board is adequate.
A 13700K or higher, that would definitely cause trouble for this VRM. MSI know that too, so according to what power draw from the CPU this VRM can handle (mind you, without heatsinks), they hard-capped it at 135W. Meaning, whatever custom power limits you set, they will not allow more since the VRM would most likely overheat then. Because once you have an i7 or i9 -K version and you allow unrestrained power limits, you can really get the smaller boards in trouble. The powerstages in the better board models have better efficiency, so the VRM temperatures would stay much lower and you can use better CPU models.
Here you can read further where i once explained how an 11900K with a cheap Z490 board is a mismatch.
Another question mark is the PSU, this Inter-Tech is very cheap for a 700W 80PLUS Gold model, and "very cheap" in the PSU world means that you should be a bit wary of it. Because it's almost impossible to build such a PSU without saving money somewhere, and there are no professional reviews of this unit. I know from a German review of an Inter-Tech 80PLUS Bronze unit that it didn't reach the claimed efficiency, so maybe they are shipping "golden samples" for 80PLUS certification, i don't know. It's probably not high priority to swap this with something better (unlike the board), but maybe you still want to read my Guide: How to find a good PSU.
Could i help you? It would be nice to know if i explained it all for nothing, or if it could actually help you in some way. I know some of it may be hard to understand, but feel free to ask for further or more simple explanations if anything is still unclear. I just want to help in the best and most comprehensive way possible, and that means, explaining the technical background without sugar-coating anything if something isn't very good.
Hi, sorry for delay and thank you. I am actually working in the HW sector so I am familiar with what you developped. It was a bit overkill :) for me but much appreciated the lot the details and the recommendation. Still, the manufacturer should provide the max sustained power and/or TDP supported by a motherboard or display clearly compatibilty with restrictions...otherwise this could result in something close to false advertising. We were not expecting to run the 13700k at sustained 250W but certainly not locked at 125W without PL1 / PL2. At this power level, under stress, the MOSFET were not going beyond 60°C. (maybe their bios is too conservative...or there is another bottleneck they have choosen to protect) . Long story short, MSI support team agreed there was some lack of info in product documentation. We replaced the motherboard by another model it works just fine. Power supply included, tested in detail stability & efficiency (and btw PSU warranty 5 years). Best, Julien
Thanks Brother,so I have to choose B760M A with 14600k for better cost to performance ratio,iam building this for Autodesk inventor 3d where I have to assemble 200-300 parts per project,I concluded my specs bu 14600k,B760M A,RTX 4060,5200 Corsair Vengeance 32(16*2),500 gb crucial p5 plus, cooler master 650w bronze,AK400ZERODARK PLUS ,
Did you prefer AMD over Intel for Modeling/Autodesk related work,then I have an option with MSI B650m Gaming wifi+7700X Hows that combination?
I think you meant to reply under here in your thread, let's continue there so we keep it all in one topic (copy&paste your reply again there).
