Pro H610-G DDR4
p4cowor15ad02e6
Hi, sorry for my english but it's not my native language.
I recently buy a Pro H610-G DDR4 and pair it with an I3 13100 and 16gb (8x2) DDR4 3200MHZ. The DRAM light in the EZ Debug LED is orange and it won't boot. Not sure if it's a problem with the memory speed or that I need to upgrade the bios to be able to use the intel 13th gen. If the bios needs to be updated, can be done with this 13th gen, because I do not have a 12th gen cpu to do it. Thanks.
Current BIOS version is 1.2.
Pro
Virtually no 600-series board is compatible with 13th gen CPUs out of the box, it first needs a BIOS update to support them. Your CPU is only supported since BIOS v18, but you'd just install the latest BIOS version (v1A at this time).
Since MSI had the bright idea to not include the Flash BIOS Button / USB Flashback function on the H610/B660 boards, you will have no choice but to install a 12th gen CPU that's already supported, update the BIOS to the newest version, and then you can use your 13th gen CPU.
You could buy the cheapest 12th gen CPU you can find (that would be the G6900 for around 60€/USD), do the update with it, and sell it again, the loss will hopefully be just 15-20 bucks. Or you could ask a PC store in your area if they're willing to help you out with the BIOS update, probably for a similar small fee.
Update how-to, after putting in a supported CPU:
1) Get the latest BIOS. It's the topmost one on the MSI support page for your board: https://www.msi.com/Motherboard/PRO-H610M-G-DDR4/support
Only a B760M or a Z790 board would've offered support out of the box, and a Z690 board could've at least been easily updated via Flash BIOS button.
badboy2k
or get the Cheapest 12th gen CPU from Amazon use it to update the BIOS and then return it for a refund and your all good.
p4cowor15ad02e6
Ok, i'll try this and see if it fix the problem. Thank you very much for the help.
