PRO-X670-P-WIFI bios problem
i cant upgrade my bios.... i have to use 1.30 version... if i try to upgrade new version its reset and not opening windows again.... its sleeping.... i have to put back old version... i put down voltage 65. but its still same how can ı upgrade my bios??? nearly 7 month i try to upgrade my bios... if i dont upgrade ı got frozen same of the game or crash..... pls help me guys.
lostking20015bf02e6
Active member
Can you provide your ram model number?
Generally, Samsung based ram has issue with later versions of the bios.
xeizoo
Just for info, latest bios 194 works very well with Hynix M-die which I'm using 6200c30 @ 2167 fclk, I guess I should be considered lucky for choosing the "right" RAM
