Pro X870-P Wifi issue
Hi
I've an issue with the wifi driver, I downloaded the file but i can't install it because I'm getting error No suitable Driver message
Note: I've updated the bios to latest version
Are you using Windows 10? This board has a Qualcomm WiFi 7 / BT Combo module that doesn't work under Win10, because of the new driver architecture that only Windows 11 supports (NetAdapterCx drivers instead of NDIS drivers). But Win11 is recommended anyway nowadays, because then you won't have to do the big upgrade to Win11 within a year's time, when Win10 support ends.
Hi
I'm using Windows 11
You can try this about the drivers. The file qualcomm_ncm865_wifi.zip, just extract it, don't run the driver installer. Press WIN+X and run Device Manager. On the top, right below the menu, you have a few icons, one of them is "Add drivers". Click on it and point it to the folder from the extracted ZIP file. See if it installs that way.
Otherwise, try the "deep" Clear CMOS method: Unplug all USB devices, unplug mains power from PSU. Press Power button to clear any residual power. Take out the CMOS battery, press the power button again. Wait a minute and put it back in.
