- Sep 9, 2004
PRO Z690-A DDR4 and WIFI discussion thread.
Latest official BIOS: v11
For me, the ease of installation, even pressure and lack of stress on the CPU is worth the frame cost even without lower temp. However I agree with your conclusion.I got some results from testing the Thermalright 1700 BCF on my 12700k (stock clocks). I also managed to get my hands on the Thermal Grizzly frame that i had to install for my best bud (he bought it from Germany, took it almost 3 weeks to arrive).
First of all, the i got my Thermalright from alliexpress, and it cost me 12.5€ (european warehouse). It was the original frame, with a genuine sticker on the box that can be used to check authenticity on website.
Upon removing my Arctic Liquid Freezer II 280, i saw this:
To me, it seems like there is perfect contact in the middle, but not in the sides that the ILM is actually applying pressure on the CPU. But again, the middle section of the CPU is most important, since all cores are there.
I cleaned all thermal paste with alcohol, and used an old card with a light source behind to check if the CPU is bended. And i got this:
... it looks like it's bended, but not that much that most people should worry about.
I was also surprised to see that the original LOTES / MSI ILM already had washers (of some short) on the bottom. Correct me if i'm wrong, but i think that in other CPU sockets, the ILM did not have those black washers. Maybe it is their attempt to ease the pressure on the chip? I have no idea...
Now, the big question, will it un-bend when ILM is loose? I was happy to see that it gets flat. The following picture is with the ILM removed, and it looks flat.
... and another one with the thermalright frame installed:
Now, installation as easy as it can get. Easier than the Thermal Grizzly's frame. The thermalright frame has the actual height needed to put enough pressure on the CPU to work and pins have correct contact. That means that you can actually bottom down the screws without worrying if you apply to much or too low pressure. At lease on MSI z690 pro wifi, it works as intended. I just didn't go crazy on tighten the screws, just applyied normal pressure on them and felt the screws bottomed down...
On the Thermal Grizzly frame, the frame height of the frame is lower than this one. That might make it compatible with more mobos (i have no idea even if that statement is correct), but that makes it harder to calculate how much pressure is needed so that you wont tighten the screws too much or too little.
Now, the test results... I just run several Cinebench R23 benchmarks to see if the results i get are similar, to exclude any type of thermal error. I have 3 screenshots with the standard ILM, and 3 screenshots with the thermalright frame installed. These screenshots are right at the start of the benchmark, after 5mins running a 10min benchmark (middle of the test) and right after it finishes. You will also see other temps in the screenshots, like nvme and GPU temps, but just ignore them. I used the latest HWInfo. CPU was running on stock clocks, only XMP is enabled in BIOS.
All my tests were done with high ambient room temperature (30C). That was intentional, since i didn't want to have any air conditioning in the room while testing.
With stock ILM, and without the thermalright frame installed, i got this:
Now, with the Thermalright frame installed, i got this:
As you can see, temperatures are lower... -6C on cpu package at the middle of the benchmark.
My 2cents on this, if you are a hardcore overclocker, go for it...
... if you are a gamer or a professional, don't bother...
I hope i helped those who are thinking of buying one of these frames... Just don't get the Thermal Grizzly one... it simply does not worth it, its 3 times more expensive and harder to install.
Bios 1.70 is not stable att all. 1.20 and 1.40 1.20 Is the best when it comes to memory overclocking, 1.40 is the best if you have 12900ks.
Mine's not.Is this motherboard bad or are all Z690 motherboards this buggy?
In Bios >F7 advanced>overclocking look for DRAM info it is included along with frequency in middle column.How do you tell what gear your ram is running?
I completely removed thje MSI Pro Z690-A and replaced it with an ASUS Prime Z690-P motherboard. Everything works as it should I lost a couple SATA ports, but I was able to confirm that all my components work fine with the ASUS motherboard. I am going to get an RMA on the MSI motherboard for repair/replacement.Mine's not.
You sure tried everything on that board. MSI should replace it with an upgrade. How do you like the ASUS bios in comparison (disregarding all the issues/problems).I completely removed thje MSI Pro Z690-A and replaced it with an ASUS Prime Z690-P motherboard. Everything works as it should I lost a couple SATA ports, but I was able to confirm that all my components work fine with the ASUS motherboard. I am going to get an RMA on the MSI motherboard for repair/replacement.
Good guesses--it seems better for MSI to be vague and indirect in order to avoid delineating the actual shortcomings.So, does that mean this new BIOS is compatible to more RAM kits? Or do they mean this newest BIOS trains better?
This is on my list to get.testing the thermalright frame, having similar performance as the much more expensive thermal grizzly one... as tested by myself a few posts back.
With previous BIOS, i lost XMP stability. It seems it tries to operate ram at 1.15v and it can't post. I have to manually set voltage at 1.35v. Maybe they fix this kind of issue. I guess i'll flash the new one and find outHey guys - so, I went ahead and flashed the newest bios (7D25v17) for Pro Z690-A DDR4. I see that it's ready for Raptor Lake, but it also says, "fine-tuned memory compatibility." Anyone know what they mean by this?
