- Sep 9, 2004
PRO Z690-A DDR4 and WIFI discussion thread.
Latest official BIOS: v11
Go to BIOS settings > Overclocking > advanced CPU configurationAlso, I notice ridiculously high VCore spikes during benchmark run (>1.45V) which causes CPU to boil (95-97°C)
Enhanced TurboOn the MSI boards, it's called MSI enhanced boost
Would you be so kind to point me where in bios I can find that option?undervoltage control in cpu setting
Overclocking- advanced CPU- undervolt protection.Would you be so kind to point me where in bios I can find that option?
This helped with VCore spikes indeed, keeping it max at 1.25-1.27V, however I still have quite low value in CB R23 (now under 21k). To my surprise, CB R20 shows me that Effective Frequencies for both P/e_cores are maintained during the test and the score is similar to what I have seen from reviews... Can this be issue with CB R23 only?Go to BIOS settings > Overclocking > advanced CPU configuration
CPU lite load control - Normal
CPU lite load - Mode 1
Overclocking >DigitAll Power
CPU Loadline Calibratrion Control - Mode4
Overclocking > CPU features
Intel Virtualization Tech - Disable
Intel VT-D Tech - Disable
(Enable if you run virtual machine application like VirtualBox)
You're very welcomeThis helped with VCore spikes indeed, keeping it max at 1.25-1.27V
For testing purpose > Try(...) however I still have quite low value in CB R23
According to chart in this post, that combination should have the option where you can set IA CEP to Disable.i planning pair z690-a ddr4 with intel 13500
At this stage of bios updates, can you confirm if i can undervolting the cpu with adaptive+offset / cpu lite load / power limit without performance drop ?
