- Oct 12, 2016
Yes he does.or do you use a splitter?
Yes i use a 3 fan splitter that came with my Kraken x63, i'm about to buy a fan hub to use the rest of my fans on that connector instead of waiting for a bios updatehow do you mean that? there is only one pump connector - or do you use a splitter?
I got it to work via a program called "fancontrol" it's some open source program that works pretty well, but only for the pump_fan header :/okay i just tried using the pump header but with the exact same result - dc fan still running at 100% and curve doesn’t affect anything
thanks for the advice, i already tried it with fancontrol aswell, unfortunately it behaves exactly like in the bios and msi center.I got it to work via a program called "fancontrol" it's some open source program that works pretty well, but only for the pump_fan header :/
any news?i sent a support request to msi, also linked this thread. will keep y'all posted
any news?
MSi have been made aware of the Problem but no ETA on a BIOS fix yetYes he does.
Humm OK
Wow... That sucks.
Your fine with 4 Pin PWM fans just not teh 3 pin DC fansHi all,
Since my last visit, I bought a set of x5 EZDIY pwm fans. Reading your answers, i'm disappointed about this MB. Are they doing an update in the future ?
Without this problem, i think it's a good and affordable board for the 12th genAre you generally happy with the board? I am considering buying it for 12600KF.
