Had a working PC for a couple of years using this motherboard. Have just replaced the Hard Drive with a Samsung 860 EVO Sata SSD. Can boot from Windows USB installer and Windows 10 installs on the SSD. However cannot then get the computer to boot from the SSD. Everything looks right in the BIOS but motherboard just doesn't want to recognise the SSD as a boot device. Makes no difference if I swap to a different SATA port on the motherboard, also no difference if I use different data and power cables. If I replace the SSD with the old hard drive, motherboard boots no problem!
SSD seems fine (SMART reports no errors), and if I use WIN PE (or equivalent) then there are two partitions on the drive (300MB EFI System partition, and 230 GB NTFS partition; which contains files, ready for Windows to continue to install).
It's driving me absolutely nuts. Also running the latest BIOS firmware on the motherboard. Anyone got any ideas?
