PROBLEM FOR MSI PM8M2-V
Status
Not open for further replies.
M
Mrguru
Guest
I have a MSI PM8M2-V Motherboard with a 400W PSU, and when I turn on my PC nothing happend. The CPU is a P4 3.2 Ghz whit his cooler.
Maesus
GENERAL OF THE ARMY
did you plug the PSU cable to the power cord on the wall? :) I'm asking this just to remind you to check every connections is OK, especially the ATX12V must be plugged to the motherboard as well.
What's your system specs? When you say "nothing happened", does the fan even try to spin? Did you plug in the PowerSwitch connector of your casing to the board? Is the connection correct? etc etc
M
Mrguru
Guest
All the cables of the PSU are connect correctly, and the PC cabinet cables too.
When I turn On my PC the fans start but nothing happen, the VGA doesn't show images and I can't hear BIOS beep. The PSU is an Aopen at 400 Watts.  :nooo:
What it could be???  :shocked_anim:
NovJoe
GENERAL OF THE ARMY
Please list out your full system specs + PSU specs amps.
Check for shortings as well.
M
Mrguru
Guest
CPU: P4 3.2Ghz Intel 800Mhz FSB 2MB L2 cache mod.LGA775
Motherboard : MSI PM82M2-V Chipset VIA P4M800+VT8237
PSU: AOPEN mod. AO400-12AHNF
      INPUT 220/240 V Output 400W (+3.3V & +5V= 150 Watt MAX)
                                                  (+3.3V ~- 30A
                                                  +5V        28A
                                                +12V1      14A
                                                +12V2      15A
                                                  +5Vsv        2A
                                                -12V 0.5A)
RAM: KINGSTON KVR400S4R3A/512 (512 MB PC3200 CL3ECC 184PIN DIMM) 400
Maesus
GENERAL OF THE ARMY
does this board come with D-Bracket? If yes, what's the D-Bracket status?
If no, have you tried to reset BIOS?
No beep? This is a value board I'm afraid it doesn't have built-in speaker... I'm not sure though. If that's the case, connect to an external speaker ?(hopefully you have one).
If still no beep, try a more powerful PSU.
Maesus
GENERAL OF THE ARMY
I've just checked the CPU support list. What exactly is your CPU? is it 640 or 641?
Maesus
GENERAL OF THE ARMY
OK, good, the CPU is supported. how about the rests of the questions?
M
Mrguru
Guest
SO... I connect speaker but i can't hear a beep. When I turn on the led of HDD and Power led start, fans start too but on my monitor i can't see nothing and the system is like stopped... I'm crazyng
Maesus
GENERAL OF THE ARMY
How about the D-Bracket? Does your motherboard come with the D-LED bracket?
Maesus
GENERAL OF THE ARMY
I just look at the board's picture from the website. It doesn't have built-in speaker. you got to hook it up to a beeper or casing speaker. Not plug your entertainment speaker from the back-panel.
M
Mrguru
Guest
All the components of the case Speacker SW Power Reset HD led are connect. I have just reset the BIOS, so I think is a PSU problem.
Maesus
GENERAL OF THE ARMY
It could be... try out with a more powerful PSU then, the one with high current rating at +12V.
NovJoe
GENERAL OF THE ARMY
Did the fans spin when you switch on the system?
NovJoe
GENERAL OF THE ARMY
Apart from getting the power supply, you can also try borrowing some RAMs and swapping them into the system.
If not, you can take you RAMs to another similar build system and run Memtest86 to see if the RAMs run into any errors.
J
Jena138
Guest
I'm having the same problem here,same board,but different cpu,
p4 2.93 ghz, power supply is 430 watt,512 ddr rams,everything is getting power, have no video at all,just a black screen,no post.
Tried every thing ,different video cards,taking it all apart and check all the hardware.still nothing.
Status
