hey guys,
need some help here. my setup is a MS-7522 ver 3.1 mother board.
6GB RAM
MSI GEFORCE N470 GTX
WINDOWS 7 PRO 64BIT
since i bought it from last year, its not stable and having an occasionally blue screen specially
when using it with heavy processing softwares such as 3dsmax and adobe cs4.
what i did the past 2 days ago is i reformatted and reinstall a fresh windows 7 pro OEM OS.
still, having some occassionally blue screen about memory management. i installed a whocrashed software
and diagnosed it resulting a driver problem and kernel stuffs.
another thing, when i update the win 7. it wont install almost around 70 important updates.
i also diagnose the RAM using the windows memory dump diagnostic but so far it succeeded the test.
i also tried to update the BIOS using a USB boot. im still having the same problem...
what can cause such problem? is it the motherboard, the ram, or the graphics card? driver issues maybe?
hoping i can find answers here and suggest what can i do to fix this.
thanks.
6GB RAM
WINDOWS 7 PRO 64BIT
thanks.
