Problem with my USB-C on my MAG321CURV monitor
stephen_chan
Hi!
I want to use the USB-C port on my monitor, so I connect it directly from my thunderbolt port of my 2017 iMAC to the monitor.
Nothing happens. It will work with HDMI and the DP ports, but the USB-C doesn't work at all.
Any advice/tips?
Best regards,
Stephen
The USB-C is for DP and Charge. So you can either charge a USB-C device or use it for display port (USB-C to DP). Pure USB-C display connections via alt mode like used on Apple computers is not supported.
