Problem with PH-GTX1050TI-4G
Hi, I have a problem with my "new" graphics card (PH-GTX1050TI-4G).
When I connected it to the computer it appeared black screen with "B2" in the lower right corner
and "_" in the upper left corner. I have read on the net that I should update my BIOS who is pretty old..
I'm not sure where can I find the latest version of it and will it work at all? Any help?
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz, 3392 Mhz, 4 Core(s), 8 Logical Processor(s)
BaseBoard Product: Z68A-GD65 (MS-7681)
Alan J T
🙈 🙉 Just 🐝 🤬😈
Link for your Motherboard BIOS and other stuff you may need like drivers. You may also need to config your BIOS on the Motherboard to work with the GPU
Do not think doing a BIOS update will make much of a difference as GPU was released long after the lad BIOS update for your board but wont hurt to try.
Plus your in the Wrong Section should be posted in the Gaming Motherboard section
