- Oct 4, 2016
Hello!
I have a recurring problem that I can't seem to solve on my own and hope I can get some help here.
I am experiencing problems with reboots when EXPO is enabled.
If the PC has been turned off, it will start as it should.
The problem only applies to reboots (installing updates is a nightmare).
I have had the system for almost a year, everything works except that it is not possible to reboot.
At reboot it gets stuck on the yellow LED which indicates that RAM could not be detected or failed. Left the system on for about an hour, no change.
Ran memtest with zero issues.
I flashed the latest BIOS 7D67v1E9(Beta version) yesterday but that did not solve my problem.
PC Specs:
CPU: 7800X3D
MB: PRO X670-P WIFI
MEM: Corsair 32GB (2x16GB) DDR5 6000MHz CL30 Vengeance RGB AMD EXPO (CMH32GX5M2B6000Z30K)
GPU: RTX 3080
NVMe: 2x Samsung 970 EVO
Best regards, Fredrik
PC Specs:
CPU: 7800X3D
MB: PRO X670-P WIFI
GPU: RTX 3080
