Robertomcat
- Sep 14, 2020
Hello, good afternoon.
I am using this motherboard to do some work, I am not using it for gaming or anything related. The processor is a 10900K and is cooled with custom liquid cooling, which only has a 360 × 60 mm radiator and three Noctua Redux 1700 fans.
Each fan is connected to a separate pin on the motherboard, and from time to time the fans randomly stop working. For example, they are all running perfectly for four or five days, and the next morning one stops working. To fix it I unplug the fan and plug it back in. Then maybe four or five more days go by, and another fan is disconnected and I have to go through the same process again.
The configuration of the three fans is identical for all three, and I have them set to stop spinning when the processor is not working.
The system is up to date and all the software is up to date.
What can happen? Thanks!
