dbenjaminsen7153002d1
- Apr 22, 2022
The last 1-2 months or so I haven't been able to load the 'supported CPU/RAM' lists when looking at motherboards on the website.
For example, if you navigate to a motherboard you have 3 tabs: Product specification, Detail and Datasheet.
When going into 'Detail' you get 2 links called 'See supported memory' and 'See supported processors'. When clicking on one of those links you're supposed to get an overview with filters where you can see which CPU and RAM the motherboard supports. This worked fine before but it hasn't worked for me the last 1-2 months. When clicking the links the new page just loads forever. Can load for 20minutes without anything happening.
I've tried Opera, Vivaldi, Chrome, IE and Edge but the problem persists. I have also checked to disable any blocking + deactivated firewall but it makes no difference.
Example:
www.msi.com
www.msi.com
Are these 2 links working for anyone else?
Example:
PRO Z690-A WIFI
PRO series motherboards, tuned for better performance by Core Boost, Memory Boost, Extended Heatsink Design, M.2 Shield Frozr, USB 3.2 Gen 2x2, Lightning Gen5, Front Type-C, 2.5G LAN, Wi-Fi 6E
PRO Z690-A WIFI
