ianjosej155f02da
- Nov 3, 2025
I had been trying to fix the Wi-Fi issue for several days, and every tutorial always tells you to reformat or change a thousand software settings. After so many attempts, the solution turned out to be much simpler than all that: grab an eraser and rub it on the pins of the network card (you’ll need to remove it from the motherboard).
