- Dec 16, 2014
On my Prospect 700R, I can control case fan speed when control is given to the touch panel. However, if I want better control of my fan RGB, I need to give control over to either MSi Center or Motherboard.
The problem with this is that MSi Center's Cooling Wizard has no effect on case fan speed when attempting to manually control via a Sys Fan header. Also, when giving control to the Motherboard, third-party software like Fan Control doesn't seem to take control either.
I can only assume that the built-in fan controller doesn't play well with MSi Center or third-party software. Has anyone found a way to control fan speed when Sync Mode is set to MSi Center or Motherboard? I could simply leave case Fan Control set to Panel, but then that severely limits your RGB control of the case fans.
