marcozamponi7158702e3
- Dec 10, 2024
I've searched the forum and found a lot of thread like this, but they all point in a different direction, a worn battery.
My issue is different. I almost use the laptop connected to AC power, as the battery life was always very short (about 1 hour using full power profile). Now the battery is at 80% (I've set in the preferences to charge at 80%max), AC connected, and if I disconnect the AC power, the battery slowly drop to zero in about 50 mins. Laptop is 2 years old so this is ok. And this is a sign that the battery is working, at least for 50mins.
But, if I switch off the laptop with the battery at 80%, and then I switch it on WITHOUT the AC connected, as soon as I input the Windows pin, the battery goes to zero. I can manage to see the empty battery icon, and then the laptop shutdown itself. I connect again the AC, switch it on, see the battery indicator at 3% and charging, and then in about 15 mins the battery is again at 80% (and this makes no sense as in 15 mins you cannot charge completely a battery that was 3%).
If I switch it on WITH the AC connected, do the Windows login and let the desktop appears, I can see my battery indicator at 80%, disconnect the AC and use the laptop for about 50mins (so the battery is OK, it can't be worn).
I can't remember when this started as I always use the laptop with AC and very rarely without it.
This is clearly a software issue as the battery is capable to mantain the laptop on for more or less the same time as when it was new, and losing some % is ok as it is 2 years old.
Any hints?
Pulse GL76 12UEK
OS: Microsoft Windows 11 Home 64 bit Ver.24H2(OS build 26100.2454)
HDI Build: ZS7-17L3NM4-XS1 / 13.A2.J25.15.0.8
BIOS Version: E17L3IMS.10F
BIOS Release Date: 2023/07/03
EC Version: 17L3EMS1.1090329202308:56:51
CPU: 12th Gen Intel(R) Core(TM) i7-12700H
Memory: 32 GB @ 1600 MHz
- 16 GB, DDR4-3200, Crucial Technology CT16G4SFRA32A.C16FN
Graphics: Fresco Logic IDDCX Adapter, 128 MB
Graphics: NVIDIA GeForce RTX 3060 Laptop GPU, 5996 MB
Graphics: Intel(R) Iris(R) Xe Graphics, 128 MB
VBIOS Version: 94.06.2b.00.4e
Disk: SSD, Micron_2450_MTFDKBA1T0TFK, 953,87 GB
Disk: SSD, Samsung SSD 970 EVO Plus 1TB, 931,51 GB
Network: Realtek PCIe GbE Family Controller
Network: Intel(R) Wi-Fi 6 AX201 160MHz
Network: Bluetooth Device (Personal Area Network)
Win32 SHIFT mode: Unsupportive
Power Plan: Microsoft
owerPlan\{8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c} Prestazioni elevate
UWP User Scenario: Extreme Performance, Performance: Turbo, Fan: Auto
Graphic Switch: Unsupportive
Any hints?
Pulse GL76 12UEK
