I'm running a Ci9-10980XE Cpu on my X299 Xpower Gaming AC.
PWM Smart fan control for CPU, Pump and Channel Sys1 - Sys4 work as it should, the fan point stays on the 4-Point-Fan-Curve and goes up and down as it should if the Temps go up and down.
Unfortunately it doesn't work for the 4 other Fan-Channels EXS1 - EXS4.
The fan point stays on the first point on the Fan-Curve. Always, no matter if the Temps are going up or down.
I already tried every BIOS which works with the 10980XE, but unfortunately no effect to the fan control.
Does anyone have the same problem and can help me?
